주요 콘텐츠로 건너뛰기
Sony Walkman NWZ-E438 Screen Replacement
필요한 것
  1. Sony Walkman NWZ-E438 Screen  Replacement, Disassembling Sony Walkman NWZ-E438: 1 단계, 이미지 1/1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Screen  Replacement: 2 단계, 이미지 1/1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Screen  Replacement, Screen: 3 단계, 이미지 1/1
    • Pull up the 2 copper strips connecting the outside of the device to the inside of the device.
  4. Sony Walkman NWZ-E438 Screen  Replacement: 4 단계, 이미지 1/1
    • Using the small, plastic prying tool wedge it between the bottom of the frame and the outer frame.
    • Slowly circle the device, popping the outside of the frame off.
  5. Sony Walkman NWZ-E438 Screen  Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • To remove the screen, use the fine point tweezers and lift up on the metal piece at the bottom of the frame.
  6. Sony Walkman NWZ-E438 Screen  Replacement: 6 단계, 이미지 1/1
    • To remove screen from metal backing, use fine point tweezers to go in between the screen and metal backing and slowly pull them apart.
  7. Sony Walkman NWZ-E438 Screen  Replacement: 7 단계, 이미지 1/1
    • The screen will be removed.
결론
Cheryl Zinn
회원 가입일: 10/08/15
525 평판
안내서 5개 작성하였습니다
댓글 한 개
wher buy display
Pavel Drobny - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 713
