소개
This guide will walk you through the steps to removing and replacing the headphone audio jack on the walkman.
필요한 것
Remove the two black 6.4mm Phillips screws from the back of the device.
Remove the two 2.8mm silver Phillips screws on the sides of the frame.
Insert a plastic prying tool between the bottom of the case and the motherboard.
Pry up the assembly and lift it away from the case.
다른 2명이 해당 안내서를 완성하였습니다.
