주요 콘텐츠로 건너뛰기
Sony Walkman NWZ-S764 Bluetooth module Replacement
필요한 것
  1. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: 1 단계, 이미지 1/3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: 1 단계, 이미지 2/3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: 1 단계, 이미지 3/3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Bluetooth module Replacement: 2 단계, 이미지 1/3 Sony Walkman NWZ-S764 Bluetooth module Replacement: 2 단계, 이미지 2/3 Sony Walkman NWZ-S764 Bluetooth module Replacement: 2 단계, 이미지 3/3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Bluetooth module Replacement: 3 단계, 이미지 1/2 Sony Walkman NWZ-S764 Bluetooth module Replacement: 3 단계, 이미지 2/2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Bluetooth module Replacement: 4 단계, 이미지 1/2 Sony Walkman NWZ-S764 Bluetooth module Replacement: 4 단계, 이미지 2/2
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: 5 단계, 이미지 1/3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: 5 단계, 이미지 2/3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: 5 단계, 이미지 3/3
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 Bluetooth module Replacement: 6 단계, 이미지 1/3 Sony Walkman NWZ-S764 Bluetooth module Replacement: 6 단계, 이미지 2/3 Sony Walkman NWZ-S764 Bluetooth module Replacement: 6 단계, 이미지 3/3
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
결론
John Ferguson
회원 가입일: 01/21/15
657 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-2, Brown Winter 2015 USF Tampa, Team 4-2, Brown Winter 2015 회원
USFT-BROWN-W15S4G2
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 646
