주요 콘텐츠로 건너뛰기
Sony XAV-AX100 Display Replacement
필요한 것
  1. Sony XAV-AX100 Display Replacement, USB Cable: 1 단계, 이미지 1/3 Sony XAV-AX100 Display Replacement, USB Cable: 1 단계, 이미지 2/3 Sony XAV-AX100 Display Replacement, USB Cable: 1 단계, 이미지 3/3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 Display Replacement: 2 단계, 이미지 1/2 Sony XAV-AX100 Display Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 Display Replacement: 3 단계, 이미지 1/1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 Display Replacement: 4 단계, 이미지 1/1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 Display Replacement: 5 단계, 이미지 1/3 Sony XAV-AX100 Display Replacement: 5 단계, 이미지 2/3 Sony XAV-AX100 Display Replacement: 5 단계, 이미지 3/3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
  6. Sony XAV-AX100 Display Replacement, Motherboard: 6 단계, 이미지 1/2 Sony XAV-AX100 Display Replacement, Motherboard: 6 단계, 이미지 2/2
    • Disconnect the display power cable from the motherboard.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  7. Sony XAV-AX100 Display Replacement: 7 단계, 이미지 1/3 Sony XAV-AX100 Display Replacement: 7 단계, 이미지 2/3 Sony XAV-AX100 Display Replacement: 7 단계, 이미지 3/3
    • Unscrew the four 3.5mm Phillips #0 screws from the motherboard.
    • Use a spudger to gently lift the motherboard up and out of the radio.
  8. Sony XAV-AX100 Display Replacement, Display: 8 단계, 이미지 1/1
    • Remove the four 3.5mm Phillips #0 screws from the sides of the display.
  9. Sony XAV-AX100 Display Replacement: 9 단계, 이미지 1/2 Sony XAV-AX100 Display Replacement: 9 단계, 이미지 2/2
    • Remove two 3.5mm Phillips #0 screws from the back of the head unit.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Abdulaziz Redha
회원 가입일: 02/22/18
741 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G5, Cagle Spring 2018 USF Tampa, Team S1-G5, Cagle Spring 2018 회원
USFT-CAGLE-S18S1G5
2 회원들
안내서 5개 작성하였습니다
댓글 3개
Where do you get a replacement screen?
I need one for a xav 3005 db
Morten Hjorth-Johansen - 답글
Thank you very much for this great write up.
However after having performed it, if all you are doing is replacing the screen, then steps 1, 4, 5 and 7 are actually completely unnecessary . There is no need to remove the back panel or the motherboard.
but thank you nonetheless for having shown the way.
Robert Edwards - 답글
I need to get a replacement screen for a Sony xav 1500 any idea of a cheap place?
Abelardo M. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 62
전체 시간: 4,976
