주요 콘텐츠로 건너뛰기
Sony XAV-AX100 USB Cable Replacement
필요한 것
  1. Sony XAV-AX100 USB Cable Replacement, USB Cable: 1 단계, 이미지 1/3 Sony XAV-AX100 USB Cable Replacement, USB Cable: 1 단계, 이미지 2/3 Sony XAV-AX100 USB Cable Replacement, USB Cable: 1 단계, 이미지 3/3
    • Place the device on a flat surface, upside down, so the bottom of the screen would be facing upwards.
    • Remove the ten 3.5mm Phillips #0 screws from the back plate.
  2. Sony XAV-AX100 USB Cable Replacement: 2 단계, 이미지 1/2 Sony XAV-AX100 USB Cable Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to remove the back plate.
    • Don't remove completely as there will still be cables connected.
  3. Sony XAV-AX100 USB Cable Replacement: 3 단계, 이미지 1/1
    • Disconnect the USB cable from the display board.
  4. Sony XAV-AX100 USB Cable Replacement: 4 단계, 이미지 1/1
    • Adjust the rubber holders that are keeping the USB cable still on the motherboard, so you can remove the cable entirely from the inner compartment.
    • The rubber holders are extremely sensitive to any applied force. Therefore, be careful while turning them around.
  5. Sony XAV-AX100 USB Cable Replacement: 5 단계, 이미지 1/3 Sony XAV-AX100 USB Cable Replacement: 5 단계, 이미지 2/3 Sony XAV-AX100 USB Cable Replacement: 5 단계, 이미지 3/3
    • Remove the 3.5mm Phillip #0 screw that secures the USB cable to the back panel.
    • Pull the USB cable off of the back plate.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abdulaziz Redha
회원 가입일: 02/22/18
741 평판
안내서 5개 작성하였습니다
USF Tampa, Team S1-G5, Cagle Spring 2018 USF Tampa, Team S1-G5, Cagle Spring 2018 회원
USFT-CAGLE-S18S1G5
2 회원들
안내서 5개 작성하였습니다
댓글 3개
Where i can get replacement lead?
mudylla - 답글
where can i get a replacement lead for this please
Andy 777 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 60
전체 시간: 4,255
