주요 콘텐츠로 건너뛰기
Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement
필요한 것
  1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: 1 단계, 이미지 1/3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: 1 단계, 이미지 2/3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: 1 단계, 이미지 3/3
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 2 단계, 이미지 1/3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 2 단계, 이미지 2/3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 2 단계, 이미지 3/3
    • Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
    • Lift the camera from the right and simply wiggle out of the slot.
  3. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 3 단계, 이미지 1/3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 3 단계, 이미지 2/3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 3 단계, 이미지 3/3
    • Disconnect the back camera from the port located in the upper right corner.
    • Lift up the camera cable using the tweezers.
    • Wiggle out camera from the slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Martin Luna
회원 가입일: 09/24/14
1,858 평판
안내서 5개 작성하였습니다
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G6
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 8
전체 시간: 2,952
