주요 콘텐츠로 건너뛰기
Sony XPERIA Tablet Z SIM and SD card reader Replacement
필요한 것
  1. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: 1 단계, 이미지 1/3 Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: 1 단계, 이미지 2/3 Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Removing cover: 1 단계, 이미지 3/3
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive
    • Remove cover
  2. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, locating the SD card reader: 2 단계, 이미지 1/1
    • Locate the SD card reader in the bottom left hand corner
    • Remove all screws connecting the metal plate to the device.
  3. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Lift up: 3 단계, 이미지 1/1
    • After all the screws have been removed lift the circuit board up to wiggle free.
  4. Sony XPERIA Tablet Z SIM and SD card reader  Replacement, Disconnecting electrical tape.: 4 단계, 이미지 1/1
    • After Wiggled free place the tweezers on the piece of electrical tape connecting it to the device.
    • Once placed there lift up and disconnect the SD card reader from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Martin Luna
회원 가입일: 09/24/14
1,858 평판
안내서 5개 작성하였습니다
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G6
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
How long did it take to complete???
Steve Donnelly - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 13
전체 시간: 2,184
