주요 콘텐츠로 건너뛰기
Sony XPERIA Tablet Z Screen Replacement
필요한 것
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: 1 단계, 이미지 1/3 Sony XPERIA Tablet Z Screen Replacement, Screen: 1 단계, 이미지 2/3 Sony XPERIA Tablet Z Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: 2 단계, 이미지 1/3 Sony XPERIA Tablet Z Screen Replacement: 2 단계, 이미지 2/3 Sony XPERIA Tablet Z Screen Replacement: 2 단계, 이미지 3/3
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: 3 단계, 이미지 1/1
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: 4 단계, 이미지 1/1
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: 5 단계, 이미지 1/1
    • Clean adhesive from perimeter of frame to prepare for new screen.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Gustavo Correa
회원 가입일: 07/11/17
373 평판
안내서 1개 작성함
IUPUI, Team S5-G1, Harley Summer 2017 IUPUI, Team S5-G1, Harley Summer 2017 회원
IUPUI-HARLEY-SU17S5G1
4 회원들
안내서 3개 작성하였습니다
댓글 5개
اريدشراءاريدشراءشاشه جديده
kore ares - 답글
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - 답글
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - 답글
Wooo its self explanatory.Good work
Duncan Mwaniki - 답글
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 19
30일 전: 46
전체 시간: 6,903
