주요 콘텐츠로 건너뛰기
Sony XPERIA Tablet Z Volume Button Replacement
필요한 것
  1. Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: 1 단계, 이미지 1/3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: 1 단계, 이미지 2/3 Sony XPERIA Tablet Z Volume Button Replacement, Removing back cover: 1 단계, 이미지 3/3
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
    • Disconnect battery, to avoid electric shock, by pulling up on the white plastic as shown by the orange box.
  2. Sony XPERIA Tablet Z Volume Button Replacement, Locate the Volume module: 2 단계, 이미지 1/1
    • Locate the volume module.
    • Remove both screws using the Philips screwdriver.
  3. Sony XPERIA Tablet Z Volume Button Replacement, Lift out of Place: 3 단계, 이미지 1/1
    • Once both screws are removed grab the tweezers.
    • Then lift up on the module.
  4. Sony XPERIA Tablet Z Volume Button Replacement, Removing the Electrical tape: 4 단계, 이미지 1/1
    • Find the electrical tape connecting the module to the motherboard
    • Carefully pull out the electrical tape horizontally and remove the volume module from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Martin Luna
회원 가입일: 09/24/14
1,858 평판
안내서 5개 작성하였습니다
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G6
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 8
전체 시간: 2,396
