주요 콘텐츠로 건너뛰기
Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement
필요한 것
동영상 개요
  1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 3/3
    • Switch-off the phone.
    • Remove the battery.
  2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 3/3
    • The small bottom bezel is held by 2x locking clips.
    • Preferably use plastic tools for disassembling.
  3. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 3 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 3 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 3 단계, 이미지 3/3
    • There are 4x silver screws and 3x black screws.
    • The rear cover is held by 5x locking clips.
    • Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
  4. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 3/3
    • Remove the back cover.
    • With a plastic tool disconnect one by one:
    • LCD Display flex cable
    • Touchscreen flex cable
    • Menu Buttons Board flex cable
    • Coaxial Wire Antenna cable
  5. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 1/2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 2/2
    • Carefully remove the main board.
  6. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 6 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 6 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 6 단계, 이미지 3/3
    • Disconnect the other side of the flex cable and remove the Home Buttons board.
    • Unstick the camera button.
  7. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 3/3
    • The touch screen is stuck to the frame with double side adhesive tape.
    • By using plastic tools gently start separating.
    • At the bottom is glued on firmly because the bonded surface is larger.
    • Use a hot air to make separating more easy and safety.
  8. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 3/3
    • With a plastic tool, carefully separate the LCD display from the touch screen.
    • Clear the touchscreen from the old adhesive tape.
  9. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 9 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 9 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 9 단계, 이미지 3/3
    • Install the new LCD into the frame and put adhesive tape.
    • Be careful not to cover the holes (for the speaker, menu buttons etc.). Install the Touchscreen.
  10. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 10 단계, 이미지 1/1
결론
다른 한 분이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,308 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,535개 작성하였습니다
댓글 2개
Sir
Please help
Mera phone SONY C1504
Display connector kharab ho gya
Hai new mil sakta hai
Please help
Yogendra Singh - 답글
Jo PCB main hota hai
Yogendra Singh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 4,974
