주요 콘텐츠로 건너뛰기
소개
How to replace broken Digitizer Glass on Sony XPERIA E.
Please SUBSCRIBE to my channel ツ
동영상 개요
  1. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement, Touch Screen Glass Digitizer: 1 단계, 이미지 3/3
    • Switch-off the phone.
    • Remove the battery.
  2. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 2 단계, 이미지 3/3
    • The small bottom bezel is held by 2x locking clips.
    • Preferably use plastic tools for disassembling.
  3. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 3 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 3 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 3 단계, 이미지 3/3
    • There are 4x silver screws and 3x black screws.
    • The rear cover is held by 5x locking clips.
    • Two of them, at the bottom side are more hard for unlocking. You can use a screwdriver or other metal tool to unlock them.
  4. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 4 단계, 이미지 3/3
    • Remove the back cover.
    • With a plastic tool disconnect one by one:
    • LCD Display flex cable
    • Touchscreen flex cable
    • Menu Buttons Board flex cable
    • Coaxial Wire Antenna cable
  5. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 1/2 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 5 단계, 이미지 2/2
    • Carefully remove the main board.
  6. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 6 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 6 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 6 단계, 이미지 3/3
    • Disconnect the other side of the flex cable and remove the Home Buttons board.
    • Unstick the camera button.
  7. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 7 단계, 이미지 3/3
    • The touch screen is stuck to the frame with double side adhesive tape.
    • By using plastic tools gently start separating.
    • At the bottom is glued on firmly because the bonded surface is larger.
    • Use a hot air to make separating more easy and safety.
  8. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 8 단계, 이미지 3/3
    • With a plastic tool, carefully separate the LCD display from the touch screen.
    • Clear the touchscreen from the old adhesive tape.
  9. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 9 단계, 이미지 1/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 9 단계, 이미지 2/3 Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 9 단계, 이미지 3/3
    • Install the new LCD into the frame and put adhesive tape.
    • Be careful not to cover the holes (for the speaker, menu buttons etc.). Install the Touchscreen.
  10. Sony Xperia E C1505 C1504 Touch Screen Glass Digitizer Replacement: 10 단계, 이미지 1/1
결론
다른 한 분이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 2013년 12월 09일
186,406 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
308 회원들
안내서 1,133개 작성하였습니다
2 Comments
Sir
Please help
Mera phone SONY C1504
Display connector kharab ho gya
Hai new mil sakta hai
Please help
Yogendra Singh - 답글
Jo PCB main hota hai
Yogendra Singh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 4,895
