주요 콘텐츠로 건너뛰기
Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement
필요한 것
동영상 개요
  1. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: 1 단계, 이미지 1/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: 1 단계, 이미지 2/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement, Touch screen Glass, LCD Display, Loudspeaker, Earpiece: 1 단계, 이미지 3/3
    • Turn off the phone, remove the battery, SIM card and micro SD card.
    • The screws are Torx T4. One of them, near the microSD card reader is different.
  2. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 2 단계, 이미지 1/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 2 단계, 이미지 2/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 2 단계, 이미지 3/3
    • Use a plastic tool to remove the middle frame.
    • Loudspeaker
  3. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 3 단계, 이미지 1/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 3 단계, 이미지 2/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 3 단계, 이미지 3/3
    • Touch screen flex cable. Disconnect it.
    • LCD Display flex cable. Open the connector.
    • The logic board is held to the display frame by several plastic locking clips. Use a plastic tool to remove it.
  4. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 4 단계, 이미지 1/1
    • Earpiece.
  5. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 5 단계, 이미지 1/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 5 단계, 이미지 2/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 5 단계, 이미지 3/3
    • Release the LCD display from the main board.
  6. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 6 단계, 이미지 1/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 6 단계, 이미지 2/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 6 단계, 이미지 3/3
    • If the glass is broken, put some scotch tape to prevent it from breaking to pieces.
    • Use a hot air to soften the adhesive tape.
    • You can use a hairdryer.
    • Start with separating at the middle, where the contact area is smaller.
  7. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 7 단계, 이미지 1/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 7 단계, 이미지 2/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 7 단계, 이미지 3/3
    • Use a plastic tool for separating the glass from the frame.
  8. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 8 단계, 이미지 1/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 8 단계, 이미지 2/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 8 단계, 이미지 3/3
    • Clean the frame.
    • Put adhesive tape if the new spare part doesn't have any.
    • Be careful, don't cover the holes for the microphone, proximity sensor, etc.
    • Install the new Digitizer.
  9. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 9 단계, 이미지 1/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 9 단계, 이미지 2/3 Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 9 단계, 이미지 3/3
    • Use again hot air and some pressure to stick the glass better.
    • Start wit reassembling.
  10. Sony Xperia E1 Touch screen Glass, LCD Display, Loudspeaker, Earpiece Replacement: 10 단계, 이미지 1/1
    • That's all.
    • Did you do it successfully?
결론
다른 2명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,882 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,516개 작성하였습니다
댓글 2개
Sony xperia d2005 touch
rhaman516 - 답글
Hi I have a problem with wifi it's a hardware issue as I dropped it yesterday since from then the issue started please help me to fix it
Om Prakash - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 11
전체 시간: 12,958
