주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Sony Xperia E3 - How to disassemble the device and replace the battery.
D2202, D2203, D2206, D2243, D2202
동영상 개요
  1. Turn off the device Remove the SIM and the memory cards. Remove 4x rubber corners.
    • Turn off the device
    • Remove the SIM and the memory cards.
    • Remove 4x rubber corners.
    • There are 6x black screws Torx T4, remove them.
  2. Use a plastic tool and separate the rear bezel. Be careful for the side buttons. Be careful for the side buttons.
    • Use a plastic tool and separate the rear bezel.
    • Be careful for the side buttons.
  3. Manta(만타) 드라이버 키트
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta(만타) 드라이버 키트
  4. Disconnect the battery flex cable. Use a Hair dryer and warm little the battery. Use a Hair dryer and warm little the battery.
    • Disconnect the battery flex cable.
    • Use a Hair dryer and warm little the battery.
  5. Use the white tape on the battery to separate it from the main frame. Battery: Li-ion, 2330 mAh
    • Use the white tape on the battery to separate it from the main frame.
    • Battery:
    • Li-ion, 2330 mAh
    • model: LIS1551ERPC
    • The same battery is for Xperia M2 and Xperia M2 Aqua.
결론
다른 4명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 2013년 12월 09일
171,183 평판
안내서 307개 작성하였습니다
Master Techs Master Techs 회원
Community
293 회원들
안내서 929개 작성하였습니다
Hello
How many times I must use Hair dryer please ?
Anthony Cremois - 답글
çà serait beaucoup en langue française
Louis Mouragnon - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 34
전체 시간: 7,719
