주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Sony Xperia E3 - How to disassemble the device and to change the Glass digitizer.
D2202, D2203, D2206, D2243, D2202
동영상 개요
  1. Turn off the device Remove the SIM and the memory cards. Remove 4x rubber corners.
    • Turn off the device
    • Remove the SIM and the memory cards.
    • Remove 4x rubber corners.
    • There are 6x black screws Torx T4, remove them.
  2. Use a plastic tool and separate the rear bezel. Be careful for the side buttons. Be careful for the side buttons.
    • Use a plastic tool and separate the rear bezel.
    • Be careful for the side buttons.
  3. Disconnect the touch screen flex cable. Disconnect the battery flex cable. Disconnect the battery flex cable.
    • Disconnect the touch screen flex cable.
    • Disconnect the battery flex cable.
  4. Manta(만타) 드라이버 키트
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta(만타) 드라이버 키트
  5. With a hair dryer or heat gun warm the glass, at first for about 2-3 minutes. Use a thin plastic tool, like a plastic pick and start the separation from the underside. Do this very slow and periodically warm the glass!
    • With a hair dryer or heat gun warm the glass, at first for about 2-3 minutes.
    • Use a thin plastic tool, like a plastic pick and start the separation from the underside.
    • Do this very slow and periodically warm the glass!
    • At the beginning you have to separate the touch screen glass from the main frame.
  6. Now continue with a plastic card. AGAIN!!! Very slowly and periodically worm the glass. The LCD is thin less than a millimeter!
    • Now continue with a plastic card.
    • AGAIN!!! Very slowly and periodically worm the glass.
    • The LCD is thin less than a millimeter!
    • Remove the touch screen.
  7. Now is time to test the phone. If the LCD is OK you can order only a touch screen, if no, then you need display assembly - touch screen & LCD With a plastic pick gently scrape the glue.
    • Now is time to test the phone.
    • If the LCD is OK you can order only a touch screen, if no, then you need display assembly - touch screen & LCD
    • With a plastic pick gently scrape the glue.
    • With a cloth and isopropyl alcohol clean the LCD.
    • Don't use a lot of alcohol. if the liquid passes behind the LCD, will appear spots that you can't remove.
  8. On the new touch screen or on the main frame put adhesive sticker 3mm. Be careful not to cover the the places for the camera, sensor, earpiece, etc. Lift the logic board a little bit, so that the touch screen flex cable can pass.
    • On the new touch screen or on the main frame put adhesive sticker 3mm.
    • Be careful not to cover the the places for the camera, sensor, earpiece, etc.
    • Lift the logic board a little bit, so that the touch screen flex cable can pass.
    • It's easier if you can order the touch screen together with adhesive which is cut off specifically for model.
  9. Reassemble the device.
    • Reassemble the device.
    • That's all.
결론
다른 6명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 2013년 12월 09일
171,058 평판
안내서 307개 작성하였습니다
Master Techs Master Techs 회원
Community
293 회원들
안내서 929개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 31
전체 시간: 7,479
