메인 콘텐츠로 스킵하기
소개
E2104, E2105, E2115, E2124
How to disassemble, take apart the device and change / replace broken touch screen glass digitizer, LCD
동영상 개요
  1. Remove the back cover and any installed SIM and memory cards. There are 8x black screws Torx T4. Remove them. There are 8x black screws Torx T4. Remove them.
    • Remove the back cover and any installed SIM and memory cards.
    • There are 8x black screws Torx T4. Remove them.
  2. Remove the small black rubber at the lower left corner. Under it is the battery flex cable, disconnect it. Under it is the battery flex cable, disconnect it.
    • Remove the small black rubber at the lower left corner.
    • Under it is the battery flex cable, disconnect it.
  3. Use a plastic tool to separate the middle frame. The battery is glued to the middle frame with an adhesive tape. Loudspeaker
    • Use a plastic tool to separate the middle frame.
    • The battery is glued to the middle frame with an adhesive tape.
    • Loudspeaker
  4. Disconnect the touch screen flex cable. Under it is the LCD flex cable. Disconnect it also. Under it is the LCD flex cable. Disconnect it also.
    • Disconnect the touch screen flex cable.
    • Under it is the LCD flex cable. Disconnect it also.
  5. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  6. Remove the logic board. Be careful for the flex cables. Be careful for the flex cables.
    • Remove the logic board.
    • Be careful for the flex cables.
  7. Cover the glass with a scotch tape. Warm the glass for about  minute. With a cutter lift a little the glase to make a room for the plastic tool.
    • Cover the glass with a scotch tape.
    • Warm the glass for about minute.
    • With a cutter lift a little the glase to make a room for the plastic tool.
  8. Carefully put the plastic tool between the glass and the LCD. The tool must be thin, you can use also a plastic card. Periodically warm the glass.
    • Carefully put the plastic tool between the glass and the LCD.
    • The tool must be thin, you can use also a plastic card.
    • Periodically warm the glass.
    • Remove the display frame.
  9. Use only plastic tools and don't force the LCD. Use only plastic tools and don't force the LCD. Use only plastic tools and don't force the LCD.
    • Use only plastic tools and don't force the LCD.
  10. Install adhesive tape. It's easier if you order your touch screen together with adhesive sticker. Start with the reassembling.
    • Install adhesive tape.
    • It's easier if you order your touch screen together with adhesive sticker.
    • Start with the reassembling.
  11. That's all.
    • That's all.
결론
다른 12명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 2013년 12월 09일
165,269 평판
안내서 305개 작성하였습니다
Master Techs Master Techs 회원
Community
286 회원들
안내서 810개 작성하였습니다
Grazie! È stato davvero utilissimo. :)
Andrea DePa - 답글
Doesn't the original glass and digitalizer come out with its biadesive?
marco bigoni - 답글
First Timer here:
I've followed this and replaced the cracked screen (the clear bit).
But it still looks cracked; could it be that I have a cracked LCD thingy as well? (is that the black bit?).
If so what's the part number for that?
MartynJ - 답글
Why don't you just buy the screen which has the lcd and digitiser already assembled? That will save you a lot of hassle for only a few £'s more :)
Clems - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 103
전체 시간: 18,906
