주요 콘텐츠로 건너뛰기
Sony Xperia E4 Touch Screen Glass / LCD Display Replacement
필요한 것
동영상 개요
  1. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: 1 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: 1 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Battery Cover: 1 단계, 이미지 3/3
    • Remove the back cover and any installed SIM and memory cards.
    • There are 8x black screws Torx T4. Remove them.
  2. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 2 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 2 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 2 단계, 이미지 3/3
    • Remove the small black rubber at the lower left corner.
    • Under it is the battery flex cable, disconnect it.
  3. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 3 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 3 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 3 단계, 이미지 3/3
    • Use a plastic tool to separate the middle frame.
    • The battery is glued to the middle frame with an adhesive tape.
    • Loudspeaker
  4. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: 4 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: 4 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Logic Board: 4 단계, 이미지 3/3
    • Disconnect the touch screen flex cable.
    • Under it is the LCD flex cable. Disconnect it also.
  5. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 5 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 5 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 5 단계, 이미지 3/3
    • Remove the logic board.
    • Be careful for the flex cables.
  6. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: 6 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: 6 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement, Touch Screen Glass / LCD Display: 6 단계, 이미지 3/3
    • Cover the glass with a scotch tape.
    • Warm the glass for about minute.
    • With a cutter lift a little the glase to make a room for the plastic tool.
  7. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 7 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 7 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Carefully put the plastic tool between the glass and the LCD.
    • The tool must be thin, you can use also a plastic card.
    • Periodically warm the glass.
    • Remove the display frame.
  8. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 8 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 8 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 8 단계, 이미지 3/3
    • Use only plastic tools and don't force the LCD.
  9. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 9 단계, 이미지 1/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 9 단계, 이미지 2/3 Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 9 단계, 이미지 3/3
    • Install adhesive tape.
    • It's easier if you order your touch screen together with adhesive sticker.
    • Start with the reassembling.
  10. Sony Xperia E4 Touch Screen Glass / LCD Display Replacement: 10 단계, 이미지 1/1
    • That's all.
결론
다른 12명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,055 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,506개 작성하였습니다
댓글 4개
Grazie! È stato davvero utilissimo. :)
Andrea DePa - 답글
Doesn't the original glass and digitalizer come out with its biadesive?
marco bigoni - 답글
First Timer here:
I've followed this and replaced the cracked screen (the clear bit).
But it still looks cracked; could it be that I have a cracked LCD thingy as well? (is that the black bit?).
If so what's the part number for that?
MartynJ - 답글
Why don't you just buy the screen which has the lcd and digitiser already assembled? That will save you a lot of hassle for only a few £'s more :)
Clems - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 20,240
