주요 콘텐츠로 건너뛰기
Sony Xperia J SIM Card/Micro USB Reader Replacement
필요한 것
  1. Sony Xperia J SIM Card/Micro USB Reader Replacement, External Features: 1 단계, 이미지 1/1
    • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
  2. Sony Xperia J SIM Card/Micro USB Reader Replacement: 2 단계, 이미지 1/1
    • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
  3. Sony Xperia J SIM Card/Micro USB Reader Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
  4. Sony Xperia J SIM Card/Micro USB Reader Replacement: 4 단계, 이미지 1/3 Sony Xperia J SIM Card/Micro USB Reader Replacement: 4 단계, 이미지 2/3 Sony Xperia J SIM Card/Micro USB Reader Replacement: 4 단계, 이미지 3/3
    • Using the Torx T5 screwdriver remove the four 4.74mm screws.
    • Then remove the two 3.13mm screws
    • Lastly remove 5.90mm screw.
  5. Sony Xperia J SIM Card/Micro USB Reader Replacement: 5 단계, 이미지 1/3 Sony Xperia J SIM Card/Micro USB Reader Replacement: 5 단계, 이미지 2/3 Sony Xperia J SIM Card/Micro USB Reader Replacement: 5 단계, 이미지 3/3
    • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
    • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
  6. Sony Xperia J SIM Card/Micro USB Reader Replacement: 6 단계, 이미지 1/1
    • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
  7. Sony Xperia J SIM Card/Micro USB Reader Replacement: 7 단계, 이미지 1/1
    • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
  8. Sony Xperia J SIM Card/Micro USB Reader Replacement, Removing parts: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the tweezers remove the clip located at the top of the phone. It should snap right off without too much pressure.
  9. Sony Xperia J SIM Card/Micro USB Reader Replacement: 9 단계, 이미지 1/1
    • Then remove the sticky pad located at the left of the phone using he tweezers.
  10. Sony Xperia J SIM Card/Micro USB Reader Replacement, Removing Parts: 10 단계, 이미지 1/2 Sony Xperia J SIM Card/Micro USB Reader Replacement, Removing Parts: 10 단계, 이미지 2/2
    • Using the tweezers lift the plate out of the clamps, from left to right.
    • Then remove the whole plate off the phone.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Arlind
회원 가입일: 01/21/15
899 평판
안내서 5개 작성하였습니다
USF Tampa, Team 4-3, Brown Winter 2015 USF Tampa, Team 4-3, Brown Winter 2015 회원
USFT-BROWN-W15S4G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 2,728
