주요 콘텐츠로 건너뛰기
Sony Xperia L2 LTE Battery Replacement
필요한 것
  1. Sony Xperia L2 LTE Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony Xperia L2 LTE Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Battery Replacement: 2 단계, 이미지 1/3 Sony Xperia L2 LTE Battery Replacement: 2 단계, 이미지 2/3 Sony Xperia L2 LTE Battery Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Battery Replacement: 3 단계, 이미지 1/1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Battery Replacement: 4 단계, 이미지 1/2 Sony Xperia L2 LTE Battery Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Carrie Schmitt
회원 가입일: 09/10/18
229 평판
안내서 2개 작성하였습니다
University of Alabama, Team S2-G6, Bedsole Fall 2018 University of Alabama, Team S2-G6, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S2G6
4 회원들
안내서 5개 작성하였습니다
댓글 2개
I do not recommend this procedure. The battery is very flimsy, can be easily deformed, and often tightly glued down. Any slight deformation can cause it to short and explode. Would be safer to get a different phone (not Sony).
eric jaehnig - 답글
Once the battery has been disconnected from PCB and you cant pry the battery out easily then it is glued in position instead of double sided tape you will need to very gently warm it up with a hair drier (not on the highest setting and not a heat gun as its too hot which will cause the battery to explode) and gently pry it out. I do recommend Sony mobiles, used them for years and are very stable, Never had a battery explode from over charging like on all Samsung mobiles. Unfortunately I learned the hard way and used too much force removing the battery that I damaged the connector on the ribbon cable for the screen. Ordered a 2nd hand L2 to replace the cable. Also its a Torx 5 needed not a torx 4 as stated at the top of the website.
Alun Jones - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 26
전체 시간: 3,179
