주요 콘텐츠로 건너뛰기
Sony Xperia L2 LTE Charging Port Replacement
필요한 것
  1. Sony Xperia L2 LTE Charging Port Replacement, Battery: 1 단계, 이미지 1/2 Sony Xperia L2 LTE Charging Port Replacement, Battery: 1 단계, 이미지 2/2
    • Before disassembling the battery, power off your Sony Xperia L2 LTE.
    • Remove SIM card tray.
  2. Sony Xperia L2 LTE Charging Port Replacement: 2 단계, 이미지 1/3 Sony Xperia L2 LTE Charging Port Replacement: 2 단계, 이미지 2/3 Sony Xperia L2 LTE Charging Port Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to pry the back case of the phone off.
    • The fingerprint sensor is connected to the motherboard.
    • Disconnect the fingerprint sensor.
  3. Sony Xperia L2 LTE Charging Port Replacement: 3 단계, 이미지 1/1
    • Unscrew all 10 screws from the top and bottom portion of the phone using a T4 Torx screwdriver.
    • Use the plastic opening tool to remove the unscrewed top and bottom portion of the phone.
  4. Sony Xperia L2 LTE Charging Port Replacement: 4 단계, 이미지 1/2 Sony Xperia L2 LTE Charging Port Replacement: 4 단계, 이미지 2/2
    • Disconnect the battery cable from the motherboard.
    • Pry up the battery and remove it from the device.
    • Battery may have adhesive that needs to be removed prior to removing the battery.
    • Be careful not to jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
  5. Sony Xperia L2 LTE Charging Port Replacement, Charging Port: 5 단계, 이미지 1/2 Sony Xperia L2 LTE Charging Port Replacement, Charging Port: 5 단계, 이미지 2/2
    • Use a plastic opening tool to lift the charging port circuit board.
  6. Sony Xperia L2 LTE Charging Port Replacement: 6 단계, 이미지 1/1
    • Unhook the antenna from circuit board using a plastic opening tool and remove the charging port circuit board from the device.
결론
Mikayla Wyatt
회원 가입일: 09/05/18
303 평판
안내서 3개 작성하였습니다
University of Alabama, Team S2-G6, Bedsole Fall 2018 University of Alabama, Team S2-G6, Bedsole Fall 2018 회원
UA-BEDSOLE-F18S2G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 646
