주요 콘텐츠로 건너뛰기
Sony Xperia M2 Logic Board Replacement
필요한 것
동영상 개요
  1. Sony Xperia M2 Logic Board Replacement, Rear Cover: 1 단계, 이미지 3개 중 1개 Sony Xperia M2 Logic Board Replacement, Rear Cover: 1 단계, 이미지 3개 중 2개 Sony Xperia M2 Logic Board Replacement, Rear Cover: 1 단계, 이미지 3개 중 3개
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Cover is plastic.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one if your spare part has come without double sided adhesive tape.
  2. Sony Xperia M2 Logic Board Replacement, Battery: 2 단계, 이미지 3개 중 1개 Sony Xperia M2 Logic Board Replacement, Battery: 2 단계, 이미지 3개 중 2개 Sony Xperia M2 Logic Board Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Disconnect the Battery Cable.
    • The battery is stuck to the phone fame. Use the white tape to remove it.
    • Li-Polymer Battery, 2230 mAh
    • Part number: LIS1551ERPC
    • Please SUBSCRIBE to my channel ツ
  3. Sony Xperia M2 Logic Board Replacement, Logic Board: 3 단계, 이미지 2개 중 1개 Sony Xperia M2 Logic Board Replacement, Logic Board: 3 단계, 이미지 2개 중 2개
    • Remove the SIM and the memory cards.
    • Remove x4 T5 Torx Corner screws & x2 T5 Torx Screws on the Board
  4. Sony Xperia M2 Logic Board Replacement: 4 단계, 이미지 1개 중 1개
    • Disconnect one by one:
    • Touchscreen flex cable
    • Proximity sensor flex cable
    • Power on, Volume buttons cable
    • SIM & Micro SD flex cable
    • Coaxial antenna cable
  5. Sony Xperia M2 Logic Board Replacement: 5 단계, 이미지 2개 중 1개 Sony Xperia M2 Logic Board Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the LCD Display flex cable. The connector is on the other side of the board, under the Power/Volume buttons flex cable connector.
    • Put one plastic spudger between the Logic board and the Main frame.
  6. Sony Xperia M2 Logic Board Replacement: 6 단계, 이미지 3개 중 1개 Sony Xperia M2 Logic Board Replacement: 6 단계, 이미지 3개 중 2개 Sony Xperia M2 Logic Board Replacement: 6 단계, 이미지 3개 중 3개
    • Step one: move aside less the left side of the board - down.
    • Step two: the left side of the Logic board must go out of the main frame.
    • For this manipulation use only plastic tools.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
ZFix
회원 가입일: 12/09/13
195,943 평판
안내서 330개를 작성함
Master Techs Master Techs 회원
Community
329 회원들
안내서 1,452개를 작성함
2가이드 댓글
My mobile charge bin problem how to find that problem , no charged my mobile…
jeeva jeeva - 답글
Removing the motherboard is unnecessarily difficult on this model! Why make it like this? One would figure the screws would do a good enough job of securing it to the frame. I guess having to wiggle it out is just part of the fun, right?
Also, getting parts for this model (and it’s water-resistant twin) sucks. I’m currently in the market for a display+touch assembly and it seems I’ll have to resort to importing from AliExpress.
Luis Alejandro Araúz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 20
전체 시간: 14,696
