주요 콘텐츠로 건너뛰기
Sony Xperia M4 Aqua Back Cover
필요한 것
  1. Sony Xperia M4 Aqua Back Cover, Back Cover: 1 단계, 이미지 1/1
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Back Cover: 2 단계, 이미지 1/1
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Back Cover: 3 단계, 이미지 1/2 Sony Xperia M4 Aqua Back Cover: 3 단계, 이미지 2/2
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Back Cover: 4 단계, 이미지 1/1
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Brian McKalip
회원 가입일: 02/10/16
2,112 평판
안내서 2개 작성하였습니다
USF Tampa, Team 4-5, Lacy Spring 2016 USF Tampa, Team 4-5, Lacy Spring 2016 회원
USFT-LACY-S16S4G5
3 회원들
안내서 8개 작성하였습니다
댓글 3개
Thanks. Do you know where to order a new back cover? Mine has shattered
Michael McNicholas - 답글
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - 답글
Reassembling just in reverse order you’ll  get a non-dust and non-waterproof device and not normally fixed rear cover.  You have to apply special Sony Xperia M4 Aqua E2303 Adhesive Sticker, 56BTUL0030A.
Andrey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 8,226
