주요 콘텐츠로 건너뛰기
Sony Xperia M4 Aqua Battery Replacement
필요한 것
  1. Sony Xperia M4 Aqua Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Battery Replacement: 3 단계, 이미지 2개 중 1개 Sony Xperia M4 Aqua Battery Replacement: 3 단계, 이미지 2개 중 2개
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
  5. Sony Xperia M4 Aqua Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove carefully, as it has the potential or tear if too much force is used.
  6. Sony Xperia M4 Aqua Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
  7. Sony Xperia M4 Aqua Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
  8. Sony Xperia M4 Aqua Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the battery once all of the adhesive is broken, and the connector is unplugged.
결론
다른 16명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
John Whitt
회원 가입일: 02/10/16
677 평판
안내서 2개를 작성함
USF Tampa, Team 4-5, Lacy Spring 2016 USF Tampa, Team 4-5, Lacy Spring 2016 회원
USFT-LACY-S16S4G5
3 회원들
안내서 8개를 작성함
댓글 11개
Hi... do you need to add some adhesive to reassemble it? Thanks.
Arief Yuha - 답글
U actually buy another back end cover that has the adhesive....
Chase Bryan -
I found that I could just push it back on with the original glue and it reattached ok.
Dave Humm -
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - 답글
Good video thanks.
I'm currently living in Thailand and they don't fix Sonys here in Krabi so I need to do it myself. Lazada has got the lcd and back cover for me, but they don't have a battery. I have a Sony Xperia aqua m4. Will the z3 battery fit...
Chase Bryan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 13
전체 시간: 20,412
