주요 콘텐츠로 건너뛰기
Sony Xperia M4 Aqua Rear Camera Replacement
필요한 것
  1. Sony Xperia M4 Aqua Rear Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Place the phone face-down, and use a heat gun or hair dryer to evenly heat the back surface until to soften the adhesive.
  2. Sony Xperia M4 Aqua Rear Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Attach a suction cup to the back of the M4 Aqua by carefully pushing down on it near the top of the phone.
  3. Sony Xperia M4 Aqua Rear Camera Replacement: 3 단계, 이미지 2개 중 1개 Sony Xperia M4 Aqua Rear Camera Replacement: 3 단계, 이미지 2개 중 2개
    • While Pulling on the suction cup, slide a thin plastic spacer (guitar picks work well) between the back cover and the phone. Slide it around the edges to break the adhesive seal. Be careful, but don't be afraid to use some force. You should hear a sticky breaking sound.
  4. Sony Xperia M4 Aqua Rear Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the back cover by pulling it from the chassis. it is flexible and can be bent, be careful.
  5. Sony Xperia M4 Aqua Rear Camera Replacement, Battery: 5 단계, 이미지 1개 중 1개
    • Remove copper plated tape and any other securing adhesive with a nylon spudger. Remove carefully, as it has the potential or tear if too much force is used.
  6. Sony Xperia M4 Aqua Rear Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Unhook the battery connector carefully. It is possible to damage the battery if too much force is used.
  7. Sony Xperia M4 Aqua Rear Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Pry the battery from the phone with the nylon spudger. There is a small amount of adhesive underneath the battery, so a bit of force is required. The battery is malleable, so it is possible to dent the battery if too much force is applied in one spot.
  8. Sony Xperia M4 Aqua Rear Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the battery once all of the adhesive is broken, and the connector is unplugged.
  9. Sony Xperia M4 Aqua Rear Camera Replacement, Rear Camera: 9 단계, 이미지 1개 중 1개
    • Remove the four hex head 3mm screws at each corner of the motherboard with a screwdriver.
  10. Sony Xperia M4 Aqua Rear Camera Replacement: 10 단계, 이미지 2개 중 1개 Sony Xperia M4 Aqua Rear Camera Replacement: 10 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove three pieces of the securing bracket using tweezers
  11. Sony Xperia M4 Aqua Rear Camera Replacement: 11 단계, 이미지 2개 중 1개 Sony Xperia M4 Aqua Rear Camera Replacement: 11 단계, 이미지 2개 중 2개
    • Detach the rear camera connector from the front of the motherboard.
    • Remove the rear camera with your fingers or tweezers.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Sarah Wetzler
회원 가입일: 02/10/16
499 평판
안내서 2개를 작성함
USF Tampa, Team 4-5, Lacy Spring 2016 USF Tampa, Team 4-5, Lacy Spring 2016 회원
USFT-LACY-S16S4G5
3 회원들
안내서 8개를 작성함
댓글 2개
Das ist kein Xperia Z3
Das ist eine Anleitung vom M4 Aqua
Faruk - 답글
That's the front camera. You have the front and rear camera mixed up!
mivanchev - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 3,548
