주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia T2 Ultra Dual Battery Replacement
필요한 것
  1. Sony Xperia T2 Ultra Dual Battery Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
    • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
  2. Sony Xperia T2 Ultra Dual Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
  3. Sony Xperia T2 Ultra Dual Battery Replacement, Removing the internal cover: 3 단계, 이미지 1개 중 1개
    • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
  4. Sony Xperia T2 Ultra Dual Battery Replacement: 4 단계, 이미지 2개 중 1개 Sony Xperia T2 Ultra Dual Battery Replacement: 4 단계, 이미지 2개 중 2개
    • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
  5. Sony Xperia T2 Ultra Dual Battery Replacement, Battery: 5 단계, 이미지 2개 중 1개 Sony Xperia T2 Ultra Dual Battery Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Using the Tweezer, carefully pry open the corresponding chips that are attached to the battery as shown. Then using the spudger, pry the battery away from the phone and watch out for the sticky substance keeping the battery to the phone.
결론
다른 25명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Christina Wojaczyk
회원 가입일: 09/26/14
1,450 평판
안내서 7개를 작성함
USF Tampa, Team 13-3, Staggers Fall 2014 USF Tampa, Team 13-3, Staggers Fall 2014 회원
USFT-STAGGERS-F14S13G3
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 16,723
