주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement
필요한 것
    1. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
      • Using the spudger, pry open the back cover by starting alongside the edge of the back cover.
      댓글 쓰기
    2. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 2 단계, 이미지 1개 중 1개
      • Once the part of the back cover has been opened up. Slide the spudger to pry completely detach the cover from the phone.
      댓글 쓰기
    1. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Removing the internal cover: 3 단계, 이미지 1개 중 1개
      • Using the Phillips #00 Precision screwdriver, take out 8 silver screws (3.15mm) and 5 gold screws (3.9mm) for a total of all the screws attached to the flat plate. 3 of the gold screws are located at the top of the phone and the other 2 screws are located at the bottom of the phone.
      댓글 쓰기
    2. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 4 단계, 이미지 2개 중 1개 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 4 단계, 이미지 2개 중 2개
      • To remove the internal cover, use the plastic spudger tool and pry the cover from the phone as shown in the picture.
      댓글 쓰기
    1. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Removing Chip: 5 단계, 이미지 1개 중 1개
      • To take out the back facing camera, flip open the flap labelled ‘film’ to reveal the chip that connects to the motherboard.
      댓글 쓰기
    2. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 6 단계, 이미지 1개 중 1개
      • Use the tweezer, carefully pry open the chip for the back facing camera.
      댓글 쓰기
    3. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Remove back facing camera: 7 단계, 이미지 1개 중 1개
      • Then using the tweezer, carefully remove the back facing camera component.
      댓글 쓰기
    1. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Removing the Front Camera: 8 단계, 이미지 1개 중 1개
      • Using the tweezer, carefully pry open the chip for the front facing camera as shown. Then using the tweezer, carefully remove the front facing camera component.
      댓글 쓰기
    1. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Removing chip: 9 단계, 이미지 1개 중 1개
      • Using tweezer, locate the audio jack as shown and pull out the chip connected to the motherboard.
      댓글 쓰기
    2. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Remove audio jack: 10 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Carefully remove the audio jack by using the tweezers and pull firmly straight out of the motherboard.
      댓글 쓰기
    1. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Motherboard: 11 단계, 이미지 2개 중 1개 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Motherboard: 11 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using tweezers, locate the battery connector and carefully pull up to disconnect it.
      댓글 쓰기
    2. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 12 단계, 이미지 2개 중 1개 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 12 단계, 이미지 2개 중 2개
      • Carefully remove the button circuit connector by using tweezers and gently pulling up.
      댓글 쓰기
    3. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 13 단계, 이미지 2개 중 1개 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 13 단계, 이미지 2개 중 2개
      • Carefully remove the silver plug by using the tweezers to lift straight up.
      댓글 쓰기
    4. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 14 단계, 이미지 2개 중 1개 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 14 단계, 이미지 2개 중 2개
      • Carefully remove the SIM card connector using tweezers by gently pulling it straight up.
      댓글 쓰기
    5. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 15 단계, 이미지 2개 중 1개 Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement: 15 단계, 이미지 2개 중 2개
      • Using tweezers, carefully remove the motherboard by pulling it up and out of the backing.
      댓글 쓰기
    1. Sony Xperia T2 Ultra Dual Dual SIM Slot Replacement, Dual SIM Slot: 16 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using the Tweezers, carefully pry the the dual SIM slot off the sticky substance used to hold it down.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Austin Kreutzjans
회원 가입일: 03/01/17
157 평판
안내서 1개를 작성함
IUPUI, Team S1-G3, Harley Spring 2017 IUPUI, Team S1-G3, Harley Spring 2017 회원
IUPUI-HARLEY-S17S1G3
4 회원들
안내서 36개를 작성함
1가이드 댓글
Clear video and tutorial!
But why make the process too long where in fact you can do it fast and simple by directly pulling out the dual sim card reader/slot off the board right after removing the mid-frame cover (after Step 4), and thereafter put in the replacement part?
The 16 steps can be done in just 5 or 6 steps.
Might as well re-title this to: Partial Disassembly of Xperia T2 Ulta Dual.
profeduards - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 24
지난 30일: 65
전체 시간: 3,533
