주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia TL Battery Harness Replacement
필요한 것
  1. Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: 1 단계, 이미지 3개 중 1개 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: 1 단계, 이미지 3개 중 2개 Sony Xperia TL Battery Harness Replacement, Remove Top Plastic Section: 1 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: 2 단계, 이미지 2개 중 1개 Sony Xperia TL Battery Harness Replacement, Remove Bottom Plastic Section: 2 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: 3 단계, 이미지 3개 중 1개 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: 3 단계, 이미지 3개 중 2개 Sony Xperia TL Battery Harness Replacement, Unscrewing the Back Off: 3 단계, 이미지 3개 중 3개
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Battery Harness Replacement, Loud Speaker: 4 단계, 이미지 3개 중 1개 Sony Xperia TL Battery Harness Replacement, Loud Speaker: 4 단계, 이미지 3개 중 2개 Sony Xperia TL Battery Harness Replacement, Loud Speaker: 4 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Battery Harness Replacement, Auxiliary Cord: 5 단계, 이미지 2개 중 1개 Sony Xperia TL Battery Harness Replacement, Auxiliary Cord: 5 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Battery Harness Replacement, Battery Harness: 6 단계, 이미지 3개 중 1개 Sony Xperia TL Battery Harness Replacement, Battery Harness: 6 단계, 이미지 3개 중 2개 Sony Xperia TL Battery Harness Replacement, Battery Harness: 6 단계, 이미지 3개 중 3개
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. Sony Xperia TL Battery Harness Replacement: 7 단계, 이미지 1개 중 1개
    • The final step is taking the entire harness off of the phone.
결론
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Adam Giniger
회원 가입일: 09/22/14
1,303 평판
안내서 8개를 작성함
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 회원
USFT-BROWN-F14S4G4
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 50
전체 시간: 584
