소개
It is one of the easier components to reach and replace. I will teach you how to remove it if it needs to be replaced.
필요한 것
Use the plastic opening tool to pry the bottom plastic section off.
Remove the four 5mm screws.
Use the plastic opening tool to pry off the back.
Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
Unhook the 2 connections between the harness and phone shell.
Using the plastic opening tool, pry the harness up and remove it.
다른 한 분이 해당 안내서를 완성하였습니다.
