주요 콘텐츠로 건너뛰기
Sony Xperia TL Display Assembly Replacement
필요한 것
  1. Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: 1 단계, 이미지 1/3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: 1 단계, 이미지 2/3 Sony Xperia TL Display Assembly Replacement, Remove Top Plastic Section: 1 단계, 이미지 3/3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: 2 단계, 이미지 1/2 Sony Xperia TL Display Assembly Replacement, Remove Bottom Plastic Section: 2 단계, 이미지 2/2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: 3 단계, 이미지 1/3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: 3 단계, 이미지 2/3 Sony Xperia TL Display Assembly Replacement, Unscrewing the Back Off: 3 단계, 이미지 3/3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Display Assembly Replacement, Loud Speaker: 4 단계, 이미지 1/3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: 4 단계, 이미지 2/3 Sony Xperia TL Display Assembly Replacement, Loud Speaker: 4 단계, 이미지 3/3
    • Use the plastic opening tool to remove the loud speaker module.
  5. Sony Xperia TL Display Assembly Replacement, Battery: 5 단계, 이미지 1/3 Sony Xperia TL Display Assembly Replacement, Battery: 5 단계, 이미지 2/3 Sony Xperia TL Display Assembly Replacement, Battery: 5 단계, 이미지 3/3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  6. Sony Xperia TL Display Assembly Replacement, Battery Harness: 6 단계, 이미지 1/3 Sony Xperia TL Display Assembly Replacement, Battery Harness: 6 단계, 이미지 2/3 Sony Xperia TL Display Assembly Replacement, Battery Harness: 6 단계, 이미지 3/3
    • Unhook the 2 connections between the harness and phone shell.
    • Using the plastic opening tool, pry the harness up and remove it.
    • There is an adhesive on the bottom half of the battery harness.
  7. Sony Xperia TL Display Assembly Replacement: 7 단계, 이미지 1/1
    • The final step is taking the entire harness off of the phone.
  8. Sony Xperia TL Display Assembly Replacement, Motherboard: 8 단계, 이미지 1/3 Sony Xperia TL Display Assembly Replacement, Motherboard: 8 단계, 이미지 2/3 Sony Xperia TL Display Assembly Replacement, Motherboard: 8 단계, 이미지 3/3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  9. Sony Xperia TL Display Assembly Replacement, Ear Speaker: 9 단계, 이미지 1/1
    • Use the plastic opening tool to detach the ear piece speaker.
    • Avoid majorly bending the tiny metal hooks holding the ear piece in.
  10. Sony Xperia TL Display Assembly Replacement, Display Assembly: 10 단계, 이미지 1/1
    • Once every single piece is removed from the main screen/digitizer this will be the only remaining piece. Nothing else can be removed. If you need to replace your screen this entire piece must be replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Giniger
회원 가입일: 09/22/14
1,303 평판
안내서 8개 작성하였습니다
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 회원
USFT-BROWN-F14S4G4
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 8
전체 시간: 546
