소개
I will teach you how to access and replace the piece.
필요한 것
Use the plastic opening tool to pry the bottom plastic section off.
Remove the four 5mm screws.
Use the plastic opening tool to pry off the back.
Use the plastic opening tool to detach the ribbon running across the battery.
Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
Use the Phillips #00 to remove the 3 5mm screws.
Lift the plastic cover off.
Use the plastic opening tool to pry the motherboard out of the phone shell.
다른 한 분이 해당 안내서를 완성하였습니다.
