주요 콘텐츠로 건너뛰기
Sony Xperia TL Headphone Jack Replacement
필요한 것
  1. Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: 1 단계, 이미지 1/3 Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: 1 단계, 이미지 2/3 Sony Xperia TL Headphone Jack Replacement, Remove Top Plastic Section: 1 단계, 이미지 3/3
    • Use the plastic opening tool to pry the top plastic section off.
  2. Sony Xperia TL Headphone Jack Replacement, Remove Bottom Plastic Section: 2 단계, 이미지 1/2 Sony Xperia TL Headphone Jack Replacement, Remove Bottom Plastic Section: 2 단계, 이미지 2/2
    • Use the plastic opening tool to pry the bottom plastic section off.
  3. Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: 3 단계, 이미지 1/3 Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: 3 단계, 이미지 2/3 Sony Xperia TL Headphone Jack Replacement, Unscrewing the Back Off: 3 단계, 이미지 3/3
    • Remove the four 5mm screws.
    • Use the plastic opening tool to pry off the back.
  4. Sony Xperia TL Headphone Jack Replacement, Battery: 4 단계, 이미지 1/3 Sony Xperia TL Headphone Jack Replacement, Battery: 4 단계, 이미지 2/3 Sony Xperia TL Headphone Jack Replacement, Battery: 4 단계, 이미지 3/3
    • Use the plastic opening tool to detach the ribbon running across the battery.
    • Use the plastic opening tool to detach the ribbon connecting the battery to the motherboard.
  5. Sony Xperia TL Headphone Jack Replacement, Sony Xperia TL Auxiliary Cord Replacement: 5 단계, 이미지 1/2 Sony Xperia TL Headphone Jack Replacement, Sony Xperia TL Auxiliary Cord Replacement: 5 단계, 이미지 2/2
    • Use the plastic opening tool to unlatch the cord's ends off the motherboard and loud speaker module. The cord can be located on the right side of the phone.
  6. Sony Xperia TL Headphone Jack Replacement, Motherboard: 6 단계, 이미지 1/3 Sony Xperia TL Headphone Jack Replacement, Motherboard: 6 단계, 이미지 2/3 Sony Xperia TL Headphone Jack Replacement, Motherboard: 6 단계, 이미지 3/3
    • Use the Phillips #00 to remove the 3 5mm screws.
    • Lift the plastic cover off.
    • Use the plastic opening tool to pry the motherboard out of the phone shell.
  7. Sony Xperia TL Headphone Jack Replacement, Headphone Jack: 7 단계, 이미지 1/1
    • Use the plastic opening tool to detach the headphone jack from the motherboard.
    • Remove the motherboard and slide the headphone jack out of its slot.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Laneau
회원 가입일: 09/22/14
435 평판
안내서 2개 작성하였습니다
USF Tampa, Team 4-4, Brown Fall 2014 USF Tampa, Team 4-4, Brown Fall 2014 회원
USFT-BROWN-F14S4G4
3 회원들
안내서 10개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 203
