주요 콘텐츠로 건너뛰기
Sony Xperia Tablet Z Battery Replacement
필요한 것
  1. Sony Xperia Tablet Z Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony Xperia Tablet Z Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Place the plastic removal tool in the corner of the object.
    • Slide the plastic removal tool along the edges.
  2. Sony Xperia Tablet Z Battery Replacement: 2 단계, 이미지 1/1
    • Remove the cover
    • Disconnect the battery, to avoid electric shock, by pulling up on the white plastic shown with the orange box.
  3. Sony Xperia Tablet Z Battery Replacement: 3 단계, 이미지 1/3 Sony Xperia Tablet Z Battery Replacement: 3 단계, 이미지 2/3 Sony Xperia Tablet Z Battery Replacement: 3 단계, 이미지 3/3
    • In the top right corner of the device remove the piece of tape connecting the front camera to the motherboard.
    • Then disconnect the camera from the motherboard.
    • Lift and remove the front camera to expose hidden screw to replace battery.
  4. Sony Xperia Tablet Z Battery Replacement: 4 단계, 이미지 1/3 Sony Xperia Tablet Z Battery Replacement: 4 단계, 이미지 2/3 Sony Xperia Tablet Z Battery Replacement: 4 단계, 이미지 3/3
    • Remove all screws connecting the battery to the tablet. Location of screws shown with red circles.
    • Then lift the left side first then detach the connection in the lower right corner. Connection shown with orange box.
    • Completely remove the battery.
결론
다른 25명이 해당 안내서를 완성하였습니다.
Martin Luna
회원 가입일: 09/24/14
1,858 평판
안내서 5개 작성하였습니다
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 회원
USFT-REMMELL-F14S15G6
3 회원들
안내서 7개 작성하였습니다
댓글 14개
Helps me with info I need for a screen replacement. I'll post pics when I complete it. need a new screen first, hard to find for that model.
evildrifty - 답글
hi,
thanks for this tutorial. do you know where I can buy the tablet battery ? thanks for your help.
safae - 답글
Same question. Where would be the best place to purchase a battery? All I've found seems sketchy and I dont want to have a time bomb on hand.
Gui L - 답글
any one actially got any andswers about were to actually get this replacement battery.. WHY OH WHY do the tuitorial without mentiong were to find the fleeping replacement?????
AvoidSonyAllTogether - 답글
Hello friends, for Sony Xperia Tablet Z 4 same way ?
thank you for support
Andi - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 26
30일 전: 195
전체 시간: 44,588
