주요 콘텐츠로 건너뛰기
Sony Xperia U Headphone Jack Replacement
필요한 것
  1. Sony Xperia U Headphone Jack Replacement, Battery: 1 단계, 이미지 1/1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Headphone Jack Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Headphone Jack Replacement, Headphone Jack: 3 단계, 이미지 1/1
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Headphone Jack Replacement: 4 단계, 이미지 1/1
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Headphone Jack Replacement: 5 단계, 이미지 1/1
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Headphone Jack Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Bader
회원 가입일: 10/07/14
545 평판
안내서 4개 작성하였습니다
USF Tampa, Team 7-2, Leahy Fall 2014 USF Tampa, Team 7-2, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,118
