주요 콘텐츠로 건너뛰기
Sony Xperia U Motherboard Replacement
필요한 것
  1. Sony Xperia U Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Motherboard Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Remove the bottom cover of the phone using the plastic opening tool.
  4. Sony Xperia U Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove the five 5.47mm and one 5.18mm Torx head screws using a Phillips #0 screwdriver.
  5. Sony Xperia U Motherboard Replacement: 5 단계, 이미지 1/1
    • Carefully remove the back cover using the plastic opening tool.
  6. Sony Xperia U Motherboard Replacement: 6 단계, 이미지 1/1
    • Pry up on the right side of the motherboard using the plastic opening tool.
  7. Sony Xperia U Motherboard Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully detach the flex cable using a pair of tweezers.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Bader
회원 가입일: 10/07/14
545 평판
안내서 4개 작성하였습니다
USF Tampa, Team 7-2, Leahy Fall 2014 USF Tampa, Team 7-2, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 7
전체 시간: 2,875
