주요 콘텐츠로 건너뛰기
Sony Xperia U Speaker Replacement
필요한 것
  1. Sony Xperia U Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Set the phone screen down on a clean flat, surface.
    • Insert the plastic opening tool into the groove located between the body of the phone, and the back plate protecting the battery.
    • Open the back of the device by prying around the sides of the back panel using the plastic opening tool.
  2. Sony Xperia U Speaker Replacement: 2 단계, 이미지 1/1
    • Insert the plastic opening tool in between the battery and the phone body.
    • Pry up on the side of battery, and remove it.
  3. Sony Xperia U Speaker Replacement, Headphone Jack: 3 단계, 이미지 1/1
    • Insert the plastic opening tool in between the white plastic cover, and the body of the phone.
    • Pop the plastic cover off. To do this, gently push forward on the plastic opening tool while it is in between the cover and the phone.
  4. Sony Xperia U Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the six size 0 Phillips screws.
  5. Sony Xperia U Speaker Replacement: 5 단계, 이미지 1/1
    • Insert the plastic opening tool in between the body of the phone and the thin plastic back cover.
    • Lift the black back cover off of the body with the plastic tool.
  6. Sony Xperia U Speaker Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Locate the earphone jack on the top left of the black plastic back cover.
    • Use the tweezers to pinch the earphone jack and remove it from the back cover.
  7. Sony Xperia U Speaker Replacement, Speaker: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using the tweezers, remove the loudspeaker module by firmly grasping it on one side, then slowly and carefully pulling the module in an upward direction.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Bader
회원 가입일: 10/07/14
545 평판
안내서 4개 작성하였습니다
USF Tampa, Team 7-2, Leahy Fall 2014 USF Tampa, Team 7-2, Leahy Fall 2014 회원
USFT-LEAHY-F14S7G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 932
