주요 콘텐츠로 건너뛰기
Sony Xperia X Back Camera Replacement
필요한 것
동영상 지침
결론
다른 2명이 해당 안내서를 완성하였습니다.
Witrigs
회원 가입일: 11/24/15
69,451 평판
안내서 378개 작성하였습니다
댓글 한 개
As repairs with adhesives go this is almost as easy as it gets. Two remarks:
The instructions say to remove the chin plate first, and later warn that you’ll need some glue or double-sided tape to put it back. Witrigs’ adhesive package does not include a strip for this, and I don’t think anyone sells one. I suspect it is possible to remove the back plate without removing the chin plate first.
Relatedly, the chin plate may deform pretty badly when you try to pry it off while the glue isn’t soft enough yet. Be patient with the heat gun and twice as patient with the hair dryer.
Minic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 6
전체 시간: 3,944
