소개
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
도구
부품
지정된 부품이 없습니다.
Use the nylon spudger to pry up the black camera connector from the motherboard.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
