이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
필요한 것
Pry up the copper connector next to the battery with the plastic opening tool.
Use the nylon spudger to pry up the black camera connector from the motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
