주요 콘텐츠로 건너뛰기
Sony Xperia XA Back Cover Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Sony Xperia XA Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Back Cover Replacement: 2 단계, 이미지 1/1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Back Cover Replacement: 3 단계, 이미지 1/3 Sony Xperia XA Back Cover Replacement: 3 단계, 이미지 2/3 Sony Xperia XA Back Cover Replacement: 3 단계, 이미지 3/3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Back Cover Replacement: 4 단계, 이미지 1/3 Sony Xperia XA Back Cover Replacement: 4 단계, 이미지 2/3 Sony Xperia XA Back Cover Replacement: 4 단계, 이미지 3/3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Back Cover Replacement: 5 단계, 이미지 1/1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Back Cover Replacement: 6 단계, 이미지 1/1
    • Peel back the RAF antenna.
결론
Anthony Hernandez
회원 가입일: 04/18/18
730 평판
안내서 3개 작성하였습니다
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 63
