주요 콘텐츠로 건너뛰기
Sony Xperia XA Battery Replacement
필요한 것
  1. Sony Xperia XA Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Battery Replacement: 3 단계, 이미지 3개 중 1개 Sony Xperia XA Battery Replacement: 3 단계, 이미지 3개 중 2개 Sony Xperia XA Battery Replacement: 3 단계, 이미지 3개 중 3개
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Battery Replacement: 4 단계, 이미지 3개 중 1개 Sony Xperia XA Battery Replacement: 4 단계, 이미지 3개 중 2개 Sony Xperia XA Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Peel back the RAF antenna.
  7. Sony Xperia XA Battery Replacement, Battery: 7 단계, 이미지 3개 중 1개 Sony Xperia XA Battery Replacement, Battery: 7 단계, 이미지 3개 중 2개 Sony Xperia XA Battery Replacement, Battery: 7 단계, 이미지 3개 중 3개
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Sony Xperia XA Battery Replacement: 8 단계, 이미지 2개 중 1개 Sony Xperia XA Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Sony Xperia XA Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Sony Xperia XA Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Lift the battery out with your hands.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cassidy Davis
회원 가입일: 04/18/18
621 평판
안내서 1개를 작성함
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G2
4 회원들
안내서 8개를 작성함
댓글 한 개
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
Mike Jurkiewicz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 13
전체 시간: 5,431
