주요 콘텐츠로 건너뛰기
Sony Xperia XA Battery Replacement
필요한 것
  1. Sony Xperia XA Battery Replacement, Back Cover: 1 단계, 이미지 1/1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Battery Replacement: 2 단계, 이미지 1/1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Battery Replacement: 3 단계, 이미지 1/3 Sony Xperia XA Battery Replacement: 3 단계, 이미지 2/3 Sony Xperia XA Battery Replacement: 3 단계, 이미지 3/3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Battery Replacement: 4 단계, 이미지 1/3 Sony Xperia XA Battery Replacement: 4 단계, 이미지 2/3 Sony Xperia XA Battery Replacement: 4 단계, 이미지 3/3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Battery Replacement: 5 단계, 이미지 1/1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
    Where can i buy this copper raf antenna
    mhel nival - 답글
    I also need it for my phone I kinda ripped it apart oops ?
    Tiybah -
    Mike J - I found that simply raising the edge overlapping the battery connector gave sufficient room to disconnect the battery so no need to remove the antenna and risk tearing!
    Mike Jurkiewicz - 답글
  6. Sony Xperia XA Battery Replacement: 6 단계, 이미지 1/1
    • Peel back the RAF antenna.
    I’ve ripped the copper part of this would I be able to get a new part or will the phone not work with out it?
    Tiybah - 답글
  7. Sony Xperia XA Battery Replacement, Battery: 7 단계, 이미지 1/3 Sony Xperia XA Battery Replacement, Battery: 7 단계, 이미지 2/3 Sony Xperia XA Battery Replacement, Battery: 7 단계, 이미지 3/3
    • Peel back the black tabs on the battery.
    • This may require some force as you are breaking the adhesive seal.
    • You will need to apply more adhesive for the reassembly.
  8. Sony Xperia XA Battery Replacement: 8 단계, 이미지 1/2 Sony Xperia XA Battery Replacement: 8 단계, 이미지 2/2
    • Use a plastic opening tool to pry up the orange battery connector that is directly above the battery in the center of the phone.
  9. Sony Xperia XA Battery Replacement: 9 단계, 이미지 1/1
    • Use a plastic opening tool to get under the battery and pry it up.
  10. Sony Xperia XA Battery Replacement: 10 단계, 이미지 1/1
    • Lift the battery out with your hands.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Cassidy Davis
회원 가입일: 04/18/18
621 평판
안내서 1개 작성함
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G2
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 26
전체 시간: 5,253
