소개
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device.
필요한 것
Apply heat to the copper RAF antenna.
Where can i buy this copper raf antenna
mhel nival - 답글
I also need it for my phone I kinda ripped it apart oops ?
Tiybah -
Mike J - I found that simply raising the edge overlapping the battery connector gave sufficient room to disconnect the battery so no need to remove the antenna and risk tearing!
다른 11명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thanks for such a clear set of instructions. I used a hair drier rather than heat gun!
