주요 콘텐츠로 건너뛰기
Sony Xperia XA Front Camera Replacement
필요한 것
  1. Sony Xperia XA Front Camera Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Front Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Front Camera Replacement: 3 단계, 이미지 3개 중 1개 Sony Xperia XA Front Camera Replacement: 3 단계, 이미지 3개 중 2개 Sony Xperia XA Front Camera Replacement: 3 단계, 이미지 3개 중 3개
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Front Camera Replacement: 4 단계, 이미지 3개 중 1개 Sony Xperia XA Front Camera Replacement: 4 단계, 이미지 3개 중 2개 Sony Xperia XA Front Camera Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Front Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Front Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Peel back the RAF antenna.
  7. Sony Xperia XA Front Camera Replacement, Front Camera: 7 단계, 이미지 2개 중 1개 Sony Xperia XA Front Camera Replacement, Front Camera: 7 단계, 이미지 2개 중 2개
    • Remove the five black 4mm screws with a Phillips #00 screwdriver.
  8. Sony Xperia XA Front Camera Replacement: 8 단계, 이미지 3개 중 1개 Sony Xperia XA Front Camera Replacement: 8 단계, 이미지 3개 중 2개 Sony Xperia XA Front Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  9. Sony Xperia XA Front Camera Replacement: 9 단계, 이미지 2개 중 1개 Sony Xperia XA Front Camera Replacement: 9 단계, 이미지 2개 중 2개
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  10. Sony Xperia XA Front Camera Replacement: 10 단계, 이미지 1개 중 1개
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  11. Sony Xperia XA Front Camera Replacement: 11 단계, 이미지 1개 중 1개
    • Use the flat end of the nylon spudger to lift the camera out of the phone.
  12. Sony Xperia XA Front Camera Replacement: 12 단계, 이미지 1개 중 1개
    • Finish removing the front camera by lifting it gently with your fingers.
결론
작성자
2다른 기여자 명과 함께
Theresa Wilcoski
회원 가입일: 04/18/18
325 평판
안내서 2개를 작성함
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G2
4 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 7
전체 시간: 406
