이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
You will need to use a source of heat. You may need to buy adhesive for the reassembly. Make sure the phone is completely powered off before opening the device. The headphone jack is held in by plastic retaining clips and may pop off when removed.
필요한 것
Pry up the copper connector next to the battery with the plastic opening tool.
With the spudger, pry the headphone jack located in the top right corner of the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
