주요 콘텐츠로 건너뛰기
Sony Xperia XA Motherboard Replacement
필요한 것
  1. Sony Xperia XA Motherboard Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Sony Xperia XA Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Sony Xperia XA Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Sony Xperia XA Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Sony Xperia XA Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Peel back the RAF antenna.
  7. Sony Xperia XA Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 1개 Sony Xperia XA Motherboard Replacement, Motherboard: 7 단계, 이미지 2개 중 2개
    • Pry up the copper connector next to the battery with the plastic opening tool.
  8. Sony Xperia XA Motherboard Replacement: 8 단계, 이미지 2개 중 1개 Sony Xperia XA Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the five black 4mm screws with a Phillips #00 Screwdriver.
  9. Sony Xperia XA Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Sony Xperia XA Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Sony Xperia XA Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Pry up the black camera case with the plastic opening tool and then remove the case.
  10. Sony Xperia XA Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Sony Xperia XA Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Pop off the small connector on the right side of the motherboard with the plastic opening tool.
  11. Sony Xperia XA Motherboard Replacement: 11 단계, 이미지 2개 중 1개 Sony Xperia XA Motherboard Replacement: 11 단계, 이미지 2개 중 2개
    • Use the spudger to take off the connector in the top right of the motherboard.
  12. Sony Xperia XA Motherboard Replacement: 12 단계, 이미지 3개 중 1개 Sony Xperia XA Motherboard Replacement: 12 단계, 이미지 3개 중 2개 Sony Xperia XA Motherboard Replacement: 12 단계, 이미지 3개 중 3개
    • Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
    • Peel back the tab past the connector.
    • Tab is stuck with adhesive.
  13. Sony Xperia XA Motherboard Replacement: 13 단계, 이미지 3개 중 1개 Sony Xperia XA Motherboard Replacement: 13 단계, 이미지 3개 중 2개 Sony Xperia XA Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Pry up the camera's connector to the motherboard with the nylon spudger.
  14. Sony Xperia XA Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Sony Xperia XA Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Use the spudger to loosen the black connector from the top right of the motherboard.
  15. Sony Xperia XA Motherboard Replacement: 15 단계, 이미지 3개 중 1개 Sony Xperia XA Motherboard Replacement: 15 단계, 이미지 3개 중 2개 Sony Xperia XA Motherboard Replacement: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Pull out the square shaped connector using tweezers.
  16. Sony Xperia XA Motherboard Replacement: 16 단계, 이미지 2개 중 1개 Sony Xperia XA Motherboard Replacement: 16 단계, 이미지 2개 중 2개
    • Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
  17. Sony Xperia XA Motherboard Replacement: 17 단계, 이미지 3개 중 1개 Sony Xperia XA Motherboard Replacement: 17 단계, 이미지 3개 중 2개 Sony Xperia XA Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Use the spudger to separate the motherboard from the frame.
    • Pull out the motherboard using your fingers.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Anthony Hernandez
회원 가입일: 04/18/18
730 평판
안내서 3개를 작성함
Cal Poly, Team S17-G2, Livingston Spring 2018 Cal Poly, Team S17-G2, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G2
4 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 2,492
