이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Stick the small suction cup on the bottom half of the back surface of the phone.
With the bottom of the device facing you, lift up on the suction cup handle.
Use the plastic opening tool around all sides to pry off the back cover.
Pry up the copper connector next to the battery with the plastic opening tool.
Pry up the black camera case with the plastic opening tool and then remove the case.
Pop off the small connector on the right side of the motherboard with the plastic opening tool.
Use the spudger to take off the connector in the top right of the motherboard.
Use the flat end of the spudger to peel up the copper tab to the right of the back camera.
Peel back the tab past the connector.
Pry up the camera's connector to the motherboard with the nylon spudger.
Use the spudger to loosen the black connector from the top right of the motherboard.
Use the spudger to detach the three copper connectors on the bottom area of the motherboard.
Use the spudger to separate the motherboard from the frame.
Pull out the motherboard using your fingers.
다른 2명이 해당 안내서를 완성하였습니다.
