소개
This guide will instruct you on how to replace the front facing camera on the Sony Xperia XA Ultra in the event the camera stops working or diminishes in quality. To complete this guide, you will need a T3 and T5 Torx screwdriver as well as a plastic spudger. A heat source, such as a hair dryer, is recommended but not necessary to completing the guide.
필요한 것
Carefully remove the back panel of the phone with a plastic spudger, or other flat and thin wedge tool. Work your way around the perimeter of the case, loosening and prying gently, until there is sufficient distance between the panel and phone.
Near the top of the battery (area closest to camera) press the small latch in the highlighted area, push the latch away from the metal casing with the metal spudger.
Use the plastic opening tool to pry off the metal case. Be sure to carefully pry the casing slowly and at multiple angles and directions to insure nothing is damaged.
다른 한 분이 해당 안내서를 완성하였습니다.
