주요 콘텐츠로 건너뛰기
Sony Xperia XA1 Ultra Battery Replacement
필요한 것
  1. Sony Xperia XA1 Ultra Battery Replacement, Back Assembly: 1 단계, 이미지 1/2 Sony Xperia XA1 Ultra Battery Replacement, Back Assembly: 1 단계, 이미지 2/2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Battery Replacement: 2 단계, 이미지 1/1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Battery Replacement: 3 단계, 이미지 1/1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Battery Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Battery Replacement: 5 단계, 이미지 1/1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Battery Replacement: 6 단계, 이미지 1/1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Battery Replacement, Battery: 7 단계, 이미지 1/3 Sony Xperia XA1 Ultra Battery Replacement, Battery: 7 단계, 이미지 2/3 Sony Xperia XA1 Ultra Battery Replacement, Battery: 7 단계, 이미지 3/3
    • Peel off the two pieces of black tape covering the battery with your hands.
  8. Sony Xperia XA1 Ultra Battery Replacement: 8 단계, 이미지 1/2 Sony Xperia XA1 Ultra Battery Replacement: 8 단계, 이미지 2/2
    • Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard.
  9. Sony Xperia XA1 Ultra Battery Replacement: 9 단계, 이미지 1/3 Sony Xperia XA1 Ultra Battery Replacement: 9 단계, 이미지 2/3 Sony Xperia XA1 Ultra Battery Replacement: 9 단계, 이미지 3/3
    • Wedge the iFixit Opening Tool underneath the battery.
    • Remove the battery by pulling up on the iFixit Opening Tool.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Jacob Jung
회원 가입일: 04/18/18
1,429 평판
안내서 9개 작성하였습니다
Cal Poly, Team S16-G3, Livingston Spring 2018 Cal Poly, Team S16-G3, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S16G3
4 회원들
안내서 9개 작성하였습니다
댓글 3개
magnificent…i successfully change a new battery for xperia xa1 ultra…its not the time yet for this xperia to retire from service to me…thank you very much
Wahyudi Hussaini - 답글
Wher did you get the batterry from? And is it good as the original?
very Green -
Where can I get the original battery
very Green - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 24
전체 시간: 10,083
