주요 콘텐츠로 건너뛰기
Sony Xperia XA1 Ultra Front Camera Replacement
필요한 것
  1. Sony Xperia XA1 Ultra Front Camera Replacement, Back Assembly: 1 단계, 이미지 1/2 Sony Xperia XA1 Ultra Front Camera Replacement, Back Assembly: 1 단계, 이미지 2/2
    • Wedge your finger under the bottom ridge of the SD card insert.
    • Pull outwards with your fingers to remove the SD card from the left side of device.
  2. Sony Xperia XA1 Ultra Front Camera Replacement: 2 단계, 이미지 1/1
    • Use a hair dryer to heat each corner of the phone.
    • Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
    • Don't heat one area for too long; the phone may get damaged from overheating.
  3. Sony Xperia XA1 Ultra Front Camera Replacement: 3 단계, 이미지 1/1
    • Press a suction cup on a heated corner of the device.
    • Hold the phone down and gently lift the suction cup to create a small gap.
    • You may hear crunching or popping sounds when you lift up the back cover.
  4. Sony Xperia XA1 Ultra Front Camera Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
    • Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
  5. Sony Xperia XA1 Ultra Front Camera Replacement: 5 단계, 이미지 1/1
    • Slide your plastic card along the side of your phone to loosen the adhesive.
    • Move the card along the sides of the phone to lift all of the corners.
  6. Sony Xperia XA1 Ultra Front Camera Replacement: 6 단계, 이미지 1/1
    • Lift up the back cover by lifting up the sides of the phone with your hand.
    • Apply a new strip of adhesive for reassembly.
  7. Sony Xperia XA1 Ultra Front Camera Replacement, Antenna Module: 7 단계, 이미지 1/2 Sony Xperia XA1 Ultra Front Camera Replacement, Antenna Module: 7 단계, 이미지 2/2
    • Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
  8. Sony Xperia XA1 Ultra Front Camera Replacement: 8 단계, 이미지 1/2 Sony Xperia XA1 Ultra Front Camera Replacement: 8 단계, 이미지 2/2
    • Insert your iFixit Opening Tool underneath the antenna module.
    • Lift up gently with the iFixit Opening Tool to remove the antenna module.
    • The antenna module may be difficult to remove.
  9. Sony Xperia XA1 Ultra Front Camera Replacement, Front Camera: 9 단계, 이미지 1/2 Sony Xperia XA1 Ultra Front Camera Replacement, Front Camera: 9 단계, 이미지 2/2
    • Insert your iFixit Opening Tool underneath the front camera and gently lift up.
    • Remove the front camera by lifting the front camera up with your hands.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Jung
회원 가입일: 04/18/18
1,429 평판
안내서 9개 작성하였습니다
Cal Poly, Team S16-G3, Livingston Spring 2018 Cal Poly, Team S16-G3, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S16G3
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 359
