소개
This guide will show you how to replace the LCD display touchscreen digitizer for your Sony Xperia XA1 Ultra if the display is cracked or unresponsive. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws, while tweezers and a spudger are needed to remove different components of the phone.
필요한 것
Wedge your finger under the bottom ridge of the SD card insert.
Pull outwards with your fingers to remove the SD card from the left side of device.
Use a hair dryer to heat each corner of the phone.
Alternate heating each corner for a minute to loosen the adhesive binding the back cover to the phone.
Consider saying “loosen” instead of “soften” so that steps 2 and 3 use the same terms. Somebody may not know that heating the glue will loosen it, and so they will be confused reading “once the adhesive is loosened” in step 3.
Press a suction cup on a heated corner of the device.
Hold the phone down and gently lift the suction cup to create a small gap.
sure that there is adhesive tape on backcover?
where should it tape on at the device inside?
looks more like only plugged together`?
이 단계에 사용된 도구:Plastic Cards$2.99
Insert your iFixit Opening Tool in the small gap between your phone and the back cover.
Lift up on the iFixit Opening Tool and insert your plastic card in the small gap between your phone and the back cover.
Slide your plastic card along the side of your phone to loosen the adhesive.
Move the card along the sides of the phone to lift all of the corners.
Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard.
Grammar, consider rewording. “Use the iFixit Opening Tool to remove the flexible orange strip which is connected to the battery from the motherboard” or “Use the iFixit Opening Tool to remove the flexible orange strip which connects the battery to the motherboard” or another alternative depending on your intended meaning.
exelente, a melhor aula de celular que eu vi.
Remove the four 4mm T5 screws on the top of the black panel securing the antenna module to the device.
Insert your iFixit Opening Tool underneath the antenna module.
Lift up gently with the iFixit Opening Tool to remove the antenna module.
Maybe add a caution that the module is hard to take off
Could use better explanation on how to take off
“to take off piece” change to take off the piece? Or even be specific, “pull with your hands to remove the module.”
also the picture makes it look as if you flip the antenna board over but it needs to be pulled up from the phone as if you bend it over it will break
Insert your iFixit Opening Tool underneath the front camera and gently lift up.
Remove the front camera by lifting the front camera up with your hands.
Use your iFixit Opening Tool to lift and disconnect the headphone jack connector piece.
Insert your iFixit Opening Tool between the back camera and the motherboard and gently lift up.
Lift up with the iFixit Opening Tool until the back camera is removed from the device.
Remove the two 4mm T5 screws connecting the motherboard to the device.
Only the bottom two screws for this part need to be removed; the top two were removed with the antenna module
Use your iFixit Opening Tool to remove the main flex (the middle orange tab) from the motherboard.
Use your iFixit Opening Tool to remove the power button flex (the left orange tab) from the motherboard.
Wedge your flathead tweezers under the flashlight module.
Lift up with your flat head tweezers to remove the flashlight module from your device.
where are the steps and pictures to remove the five screws from the plastic module on the bottom of the phone covering the charging port PCB board
다른 7명이 해당 안내서를 완성하였습니다.
How do you remove it? (Seems obvious but write for any audience, and say how to do things instead of just what to do)
Kyle Ladtkow - 답글
