소개
If your phone is running slow or looses charge very quickly, your battery might be the reason and it may be time for a replacement. This guide will instruct you on replacing the battery of your Sony Xperia XZ2.
Before removing the battery, you will have to remove the front screen. You will need a spudger and a Phillips #00 screwdriver head.
필요한 것
Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
Remove the one 3 mm Phillips #00 screws.
Remove the two 1mm Phillips #00 screws.
다른 3명이 해당 안내서를 완성하였습니다.
